Technical That Croma Wobble again
Midlands
As you can guess by the Title, i now have the dreaded front end wobble at 40 -50 miles an hour. Reading through the threads it appears to be mainly a driveshaft problem. The question is which one do i change. Can anyone how has had the problem let me know which side they changed as i will most likely go with the majority.
Regards
PaulD
Just seen your message, so things probably sorted by now. Quick test drive by mechanic should tell which one is the problem. Ours went on the righthand side first followed a year later by the left, unfortunately then out of warranty. Ours is a MkII Croma bought in May 2008 in Italy (as we live here) still can't believe such a fundamental item causes so much hassle and expense. ther has to be a design fault or component fault for so many Cromas to experience the same thing. Fiat will not admit though.
Today the car won't start. It;s been snowed in so very cold, EOBD symbol keeps flashing. Might start when warmer or its bust. We shall see!
Good luck with the driveshaft.
Regards
PaulD
Paul
I posted a thread in the early days, without going into too much detail, the driveshafts can be reconditioned, the spidex within the driveshafts collapses.
