jeanie said:
it smokes quite a bit on start up then calms down. it then sometimes smokes a lot or not at all it doesn't seem to be consistent. it seems as though its running a bit fast but i have had it into the garage and they said they turned it down ?? as much as they could. its a shame cause everything else about the car is great.
thanks
Jeanie
eace: :
Ok, did not read the posts properly, smoking on start up and then gets better is usually the injector preheaters. They look like small spark plugs, located in a row below the injectors behind the injector piping, there is a metal bar linking them all together with a thick brown wire at the right hand end.
My local garage did not know about them causing lumpy starts and smoking, and it is a common problem.
These are powered during the time the dashboard preheat light is on but the light goes out reasonably quickly, it's only an indicator, the preheaters stay on longer, usually about 1 min.
Now, either there is no power to them in the first place or 1 or more of them are duff. If you have the skill and a meter check at the brown wire for 12v (or so can be between 10 to 12v) when you turn on the ignition, it only is there for about 1min. If it IS there then you have one or more duff heaters. If no power the relay / fuse needs checking changing, this has never happened to me, its allways been the pre-heaters.
Remove the brown wire, DO NOT TURN ON THE IGNITION, (or disconnect the battery, this is a VERY high power circuit) take each small nut of the end of each heater and remove the commoning bar. With a meter set to ohms check the resistance of each one, they should be less than 5 ohms, usually about 1 ohm, can be as low as 0.6 ohms. If there is no reading at all it's died, open circuit, fallen of it's perch, deceased.
They can die randomly, one or more of the four. Replacements from your local Fiat or motor factors. Unscrew the duff one and replace. For peace of ming replace all four and keep the old good ones as spares.
The job IS fiddly due to the location behind the injector pipes but can be done in about a hour, use a ring spanner on the heaters themselves (open enders slip off) and they WILL be tight, you may need to use another spanner or a bar as an extension for leaverage in the tight space. Replace is the reverse of dismantling, don't forget the brown wire !
I hope this helps.
