Technical Tempra serious problem - help needed
Galilio_Mad
Cairo
hi guy`s
i have a 1993 tempra sx 1.6 i.e with bosch motronic ecu
it all started couple of weeks ago
the car started cutting for a second or two while driving in various conditions
hi or low rpm`s , high or low speeds , even in idle
i checked everything ( spark plugs, airbox and filter....... you name it )
i also noticed that in these seconds of cutting the injection dash light came on so i ran a injec cleaner into the fuel it got a little better but came back again , i guess it all started when i got the car belts changed so i went to check all the belts and timings they were perfect even the cam belt bullseye
3 days ago it started dying when releasing the accelerator pedal and in idle speed but in random way not all the time
so please help me it`s really starting to be a hazzard on highways
Galilio_Mad said:
hi guy`s
hy
if your injector light came on you have a problem with your injector
please get it to clean up you done the worst thing by putting injector cleaning in fuel
try cleaning !!!
