temperature sensor wires gp to mk2 punto, me stuck
Essex/Suffolk border
one the grande the colours are blue/white and yellow/white
on mk2 they one black, one white. i need to wire the gp one into the punto one, but me not know what wires to join :(
as the temp sensors are different colours and different plugs, and sit in different places on the engines i think i have to do it this way.:(
In theory they should work the same, and probably even have the same threads, so I would think the mk2 Punto sensor will do (ideally you'd want to check it all on an Examiner when you're running it up, but I'd be surprised if there's problems).
Pin numbers should be on the connector and usually repeated on the sensor too-
Wiring colours can only be a guide, Fiat fit what they have lying about sometimes :bang:-
Grande 1.4-
Pin 1 (Blue/white) Signal wire
Pin 2 (Blue/yellow) Reference earth
Mk2 Punto 1.2 Auto-
Pin 1 (Black) Reference earth
Pin 2 (Grey/white) Signal wire
Good luck Dave. Don't spend all the Bank Holiday on it will you? :D
