I think I have this problem too. The engine never seems to get up to 90 even when driven hard and then sitting in traffic. I was wondering if this is an MOT fail or if they overlook it? I have an MOT on Friday so would need to know beforehand. Also, to change the thermostat do you need to drain the coolant completely or can you preserve most of it and just top up what comes out of the thermostat housing?
Thanks.
I just changed my 899 Cinq thermostat last weekend. If the car is on level ground you don't need to drain the coolant. You disconnect the hoses to the thermostat (some coolant will be lost) and then remove the thermostat (a bit more coolant will be lost). I then poked the coolant inlet on the cylinder head to dispel some more coolant so that the coolant in the engine was a few mm below the mounting surface.
Then I made sure the surface was clean, gave it a wipe with Methylated Spirits and then fitted the new thermostat. Reconnect all pipes, top up the coolant expansion tank if noticeably low, run the engine up to operating temperature then stop the engine and check the coolant level again. Top up if needed, though wait for it to cool down first! You should then also bleed the system.
For the Sportings I would think you do the same as for the 899 ohv engine, except that the thermostat is on the side of the cylinder. I haven't done a thermostat on a Sporting but I have on a FIRE engined 999cc Uno, which by all intents and purposes uses exactly the same priciple.
Both FIRE and ohv engines can therefore have their thermostats changed without needing to drain the coolant. However, if your coolant hasn't been changed in the past couple of years then you might as well take the opportunity to drain, change and refill it and do the thermostat at the same time.
As for failing the MOT, no a faulty thermostat won't do this on its own. However, if the engine doesn't get up to operating temperature then the ECU may be running the engine in 'rich' warm up mode and you may find your emissions will be too high as a result. Then again, just leave it ticking over for about 15 minutes and it should get up to temp even with a faulty thermostat.
Thanks fingers,
I've been looking at the guide to modding the thermostat for cooler running and was wondering can i use what's left of my seized thermostat or do I have to use a fully working one to
donate parts?
You only need the housing as it's the thermostat part inside that is the bit that fails. You will be replacing this part when doing the mod. The housing is literally an empty aluminium body so as long as it's not cracked it will be fine.
