Hello,
I was wondering if it's OK to switch back and forth between two ECUs ?
The original 2005 ECU had problems so I got another one, a virginized 2008 ECU, which is currently installed.
But I got a call from the local Fiat dealership, inviting me for a test, after I complained about the problem with the original ECU.
Is it OK if I switch back to my original ECU for a day, so they can test it on the car, then go back to the new one ?
Other than the calibration procedure (rev the engine 3 times to over 4000 rpm) is there anything I should do ? Will there be problems when I switch back ?
