General Switched live for radio
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Bigmally
Hi, I have just removed my aftermarket stereo as it was causing bad battery drain. I am looking to re-fit it using a switched live. As there isn't one available, which switched live wire is the easiest to access for me to tap into. Thanks in advance.
Sorted.....:)......I was going to tap into the cigarette lighter after reading other posts on the forum. Luckily when I took off the handbrake panel, I found a spare connector just laying there doing nothing. Luckily it was also a switched +ve so I joined up, separated the 2 wires going to perm +ve on the iso and reconnected it to switched +ve.......(y).......Perfect. At least I now know that when I turn the car off, there is limited power going to the HU. Just thought I would post incase anyone else has the same problem.
