General Swift Bolero Motorhome
BeEmUu
Hi does anyone know where I can get the correct info.from with regard to the fuse boxes fitted in my motorcaravan( Fiat 100 2009)
Info in the book supplied is different to my vehicle,I cannot find fuses for the sidelights ?
Barry Wilkins
Correct - there are no fuses for the sidelights, unless fitted by the converter for extra sidelights (unlikely) in which case they will be in the bottom of the right hand side door pillar.
Try changing the bulbs. If the body computer detects the wrong wattage it will cut the power supply to them. Hence fuses would be superfluous.
My 2008 Elnagh motorhome has fuses for sidelights in the bottom of the right hand side door pillar.
The side marker lamps. Front and rear light fuses are located next to the steering wheel.
Some info on the X250 lights. I do not believe there are any discrete fuses for the front/rear sidelights
  • FIAT X250 Lights.pdf
Hi , thanks for the reply,that does explain there did not seem anything wrong with the 2 bulbs I changed. Seems it was caused by a loose connection on the front sidelight.
Barry Wilkins
