swapping exhausts
swapping exhausts
S
sly si
is they any welding involved when swapping exhausts over and how easy is it to do
Si, it well easy to remove the exhaust you got two bolts at back of cat convertor and a couple of rubbers the hard bit is twisting the exhaust enough to get it off at the back near the subframe shouldn't need any welding unless you stick a universal back box on the original exhaust, ease depends if your is a one piece exhaust from cat back..... better if split like mine.... if one peice car needs to be high up preferrably on a lift ramp thingy to twist it out...
And the beat goes on..........
it will be up on ramps and im swapping it for the full piece
Then you just need to unclip the the hand brake cable running to the n/s rear wheel just let it sag a bit dont disconnect it. Then just thread new exhaust through, as i said before you'll probably have to twist the whole exhaust round to get it through should be ok on ramps not sure as mine was on a lift 6ft in the air so i was standing under mine when i did it.
B
4
984
Dark Lurker
7
841
S
A
3
813
A
J
445
John Schmidt
J
G
6
487
Greg Crisp
G
