Technical  suspention Qs
should sit slightly higher in the front but the back will drop the full height.
might just spend the extra £50 for the specific gmax kit.. which is actually for everything other than the 45 heh.. so that doesnt make any sence :p
i think itad be fine tbh. will see tho. looking at some new wheels for it first tbh.. 15s are good but its slightly slower now and i would rather have soemthing wider than bigger.
The suspension will fit any Uno. The only difference will be the overall height. As the turbo and diesel are heavier they will be lower at the front. other models will be a little higher. If its a 35/60 kit for a turbo then it will probably be 35/35 in a 70/60 etc
A turbo kit sits about 10mm higher at the front on a 45, dunno how much higher it will be on a 70 but id imagine about the same.
