sunroof
sunroof
M
marc
my sunroof is leaking the water is not draining away iv put cables down the drains to unblock them but still no luck, its a bravo 1.4 sx 96 does anyone have any tips for me would really help as winter and rain is already here, thank
Sunroof chassis is the most problem not the drains. Chassis is bonded, over time it can let go. The fix is to remove the sunroof and heavily apply some silicon to the sunroof. The Headliner, plastic pillars, sunvisors and ceiling light need be removed to gain access.
Forgot to mention.
Aerials can leak too and so can the windscreen but its not as common as that above.
A cheap fix is to rub vaseline or similar in the crevice of the sunroof and the roof. This will temporarily stop water entering the car. If your sunroof is loose, i.e jumps up when you close the door. Pack out the sunroof seal 1st then add the vaseline or similar.
