Technical Sunroof not closing/responding to switch.
djmuir
can someone describe the drain channels/holes on the rear sunroof. i reckon water has got in the rear sunroof motor/switch assembly since the sunroof does not always respond to the switch(i've also had water running from the little plastic panel between the rear inside lights ).
is this a 'known' problem?
it looks like you have to dismantle the switch and clean it up or change new ones.
i face the same problem because of leakage and causing the switch rusty.
save my self few bucks by DIY the switch. it involve desoldering and soldering work.
I'm on my 3rd switch unit myself and it keeps rusting up. Need to find where the water leak is coming from and will do a search.
