Hi Everyone,
In my Fiat Ducato 14 2002 2.8JTD I'm having a problem with the clutch slipping.
I was on the way to the airport to drop someone off and half way I felt a change in the feel of the clutch pedal and then noticed it started to slip.
This is a brand-new issue, although there are some possibly/likely related issues...
I'll just list them below, the easiest way:
the brake calipers + pads were recently replaced, so it's unlikely to be a brake issue, also there is no excess heat from the wheel after driving.
The noise from the left wheel does not change in pitch when braking, but when you turn more to the right, the noise is louder.
The noise continues regardless of whether you are accelerating so I don't think it's the CV joint, the outer one at least.
I have inspected the outer cv boot as well which appears to be intact.
This noise actually increased in severity just on the same journey as the clutch started slipping.
The noise is not a clicking like a damaged CV joint but reminded me more of brakes, where there is subtle changes to the noise as the wheel rotates.
The two front tyres were recently changed as well, as in on the weekend, so that's something else to add.
My hypotheses -
Oil from the gearbox or engine has entered and contaminated the clutch, causing it to suddenly start slipping.
Clutch fluid was leaking, ran low and then caused the slipping - I don't believe this is true, I checked the brake fluid reservoir and its full (I thought it might share one with the clutch).
I'm quite handy (but not a mechanic) and willing to learn whatever it takes to fix this myself, but I'm concerned this one is out of my depth, mostly because I don't have a ramp to raise it up on!
I would love it if you gave any help you could, feel free to suggest next steps and images I could add to this post to help.
Also, rough estimates of cost to repair would be useful if you have any knowledge of prices.
Thank you so much, this forum is a lifesaver
- Dark/black fluid leaking from potentially the gearbox, could be engine oil though which was my first thought
- Gearbox grinding into 2nd and 4th, which has been informally diagnosed at a garage as a syncro issue
- Difficult to find/stiff 1st gear, despite best efforts, 3rd gear is usually found when looking for 1st and when you find 1st it can be tough to put it in gear
- An increasingly loud noise coming from the left wheel area, more details below:
My hypotheses -
