Hi
I have recently purchased a fiat Qubo 2010 with 16.000 km on the engine,
and is normally using 5.0 L/100Km at speed at 100 km/t, but then suddenly it uses 10 L/100km, and in idle it's running on 1100 rpm instead of the normally 800 rpm, it's vibrates and smells hot, if i try to start it will use 25 L/100km all the way op to 60 Km/t then it falls (normally it uses up to 15 L/km under acceleration), then suddenly the vibration is gone and the fuel consumption is back to normal, and the smell is gone, no warnings light or computer readouts says anything.
I have a feeling that 1 of the diesel Nozzles is going crazy, and diesel is burned in the catalyst therefor it is getting hot and smells
In the Qubo is the 1.3 multi-jet diesel engine from the fiat punto
/Kenneth
/Kenneth
