Good morning Guys,
Like previously said, I am new to this forum, and allready got plenty of help with my Stilo.
I recently bought a problem child. Problem with it is, the previous guy just didn't care for fixing her problems up
. Seems like my main problem is vacuum lines and the fuse box by the battery which could be the headache:bang:.
The vacuum lines I have mananged to connect up to where I think was the spaces for them to go. But not the vacuum lines from the valve under the aircleaner, nope, they are fine and intact, the ones I am talking about is coming from a valve underneath the EGR valve. The one I connected up to a pipe going to the intercooler, there was a little nipple on there that was blocked off, and the other seems to be on the bell housing? Never the less, I have another huge head ache.
The battery cover is not present, leaving the fuse box open to elements, such as water from below and obviously a rat made it its home sometime before I got it. I suspected the fuse box being damaged, so I took it apart completely and cleaned every plate and reassembled. But I suspect some relays being problematic aswell.
My question. Does anybody know where on the web I can find a diagram explaining the fusebox layout and what goes where etc etc? I just need to know what relay does what on the fuse box. like where is the security relay or ignition fuse or glowplugs etc. I am having a lot of lights on on my dash.
PLEASE HELP. The car wont start and say loose connection and security fault and the glowplug light doesnt go off, abs is lit, etc.
Thank you all.
Thank you all.
