Does somebody has an update FW for my car??
Thank you in advance
I posted links to the update files, and instructions to install them in post 2 of this thread:
Thank you Davren, however i already dowloaded 3 versions and non of them succesfully loaded into my navi system. after 10 pct i got an error and updating was stopped. any other solution? thank you in advance :worship:
Possibly someone has tried the update procedure incorrectly and destroyed the CN+.
I don't know of any other way to resume the procedure except what I posted in the instructions (3, 4, 5, 6, "TEL").
I TRIED IT TO UPDATE AND I FOLLOWED YOUR INSTRUCTION STEP BY STEP. AND AFTER 3,4,5,6 TEL THEN MY NAV+ COME BACK AND WORKING PROPERLY BUT WITH OLD FW (8.5)
DO YOU HAVE ANY OTHER LINK,,,
No... they are the only instructions for updating the CN+ firmware.
Please do not use all capital letters. It means you are shouting.
Have you ever use same link and succefully installed?
Yes... I've used the files on about 20 CN+s for my own and other people's units.
The v11.0 firmware has been downloaded 450 times, and the setup file 508 times. I don't recall anyone else having a problem that wasn't as a result of them using the files incorrectly.
i downloaded the update fw once more and tried to update my nav+ to 11.1, however again unsuccesfull. pls check the photo for the occured error and advice your comments![]()
Check that you have the correct files on the v11.0 disc. The file names, dates and sizes should be as below.
only the difference is the format of NIT_SH4 file, but size is the same. yours in zip file. how can i get the same one? do you have any idea?
The flasher program will be looking for files with the exact names I posted above, so it will not find NIT_SH4. I must be NIT_SH4.ZIP
Downloading the file from the downloads section gives you CN11.RAR
Unzip that with WinRar gives you an image file named CN11.ISO
Use ImgBurn to burn a CD from that image file.
I've just gone through this process and the CD burns with NIT_SH4.ZIP not NIT_SH4
I already did it with imgburn and yesterday i did it with nero but the result is the same (nit_sh4 created i/o .zip). this is really strange because all steps that i follow is the same what you mention above
I don't know what else to suggest.
Ask a friend to download the file and make the disc on a different computer perhaps???
no way Davren, i asked yesterday to my friend who has really experience on computers, unfortunatelly got same reason and error. i will try to find another fw update link, maybe![]()
