Technical Stilo abarth vibration on acceleration
rusty11
hi, my stilo abarth is juddering under acceleration but not through the steering wheel and revs are normal, it seems like its coming from the passengers side. any help would be appreciated? i've heard so far could be, driveshaft, clutch, tracking etc. the car is on coilovers
Recently had a similar problem... went through the normal checks... wheel balance and alignment, etc, but it ended up being the inner CV joint.... it is a tripod in bell housing arrangement - one of the channels had worn and restricted the movement of the tripod leg forcing the whole driveshaft to move in/out slightly as it rotated... replaced the whole driveshaft with a second hand one and it solved the vibration problem.
Best of luck!
