johns
I had a tensioner failure a few weeks ago on my Stilo Abarth after approx. 65,000 miles, so I thought I'd get all the belts changed. The tensioner got to the end of its tensioning and the belt came away from the crank pulley.
I use a company called Torque Italia in South East London to do all my tuning and maintenance work on my Fiat Coupe 20V Turbo (and it is the 2nd most powerful Fiat Coupe in the UK with 460BHP). The proprietor's name is Barbz (he's pretty much a one man band), and he is extremely well respected in the Fiat Coupe community and indeed the Lancia Delta Integrale community (used to work at Evocars/Barry Waterhouse Engineering)
Anyway, the coupe 20V/turbo engine and the Stilo abarth 20v engine are closely related, so I asked him to do my belt change. He changed all my belts, all my tensioners, fitted an uprated water pump and all the labour for £395, and he'll do anyone else for the same price. Considering what a Fiat main dealer charges I think that's a bargain!! Also considering Fiat don't always change all the ancillaries (esp. the water pump) for a lot more it makes sense to go to a renowned independent fiat specialist for the belt change even if you want to keep your routine servicing with Fiat.
I should point out that there are some subtle but important differences between the coupe and Stilo ancillaries and he was fully familiar with these as well.
So if you're due for a belt change (6 years or 72,000 miles) it's well worth giving him a shout. And if you get a lot of whining like I did before mine went maybe it's worth doing them sooner rather than later. My timing belt was extremely shiny and I think it wouldn't have lasted much longer either. It was a little suprising actually.
This is a shameless plug because he sorted me out of a tight spot by fitting me in instead of a potential 10 day wait at my local Fiat dealer!
