Don't mess about with the cam-belt. If that packs up then the car will be a write-off... but wait until you've assembled everything else first, so that you can get a picture of the overall state of the car and whether it's worth it.
The other thing to look at is the metal brake pipe. You seem to have bubbling (corrosion) underneath the plastic sleeving above the union/nut, so that's a burst pipe/leak waiting to happen.
A decent garage will be able to cut the metal pipe (e.g. somewhere between the two plastic clamps) and put a flare on the pipe in situ, then make up a new bit of pipe to replace the bit they cut off. It shouldn't be too severe (££). But they need to be able to flare the steel pipe in situ.. removing the whole pipe and replacing it would be a whole different level of PITA.
You may be able to separate the flexi hose from the stub of the metal pipe once it's been cut out of the car... (they tend to corrode terminally together and unbolting the flexi tends to twist the metal pipe) .. but for the cost and hassle, it's easier to just fit a new flexi pipe.
Ralf S.
Ralf S.
