abarthstilo
Hi all,
I bought my Stilo last Friday and its great
Love the cruise control.
I do have a few problems with it though which I guess should be expected as its almost 6 years old.
Luckily these problems aren't engine related.
Heres my list of problems/questions:
1. The drivers side door does not lock when using the remote key fob, all the other doors lock and the full closure system works but I have to keep using the key in the drivers door! This is really annoying and pretty much makes the remote central locking feature pointless. I have messed with the computer and tried changing the 'Lock drivers door separately option' but on both settings it does the same. I guess its not a critical problem but it would be nice if it worked.
2. My Connect nav+ doesn't work fully
The amplifier module and cd changer are marked red in the Service menu and the radio version is red. Everything else is green. The cd on the head unit won't eject, it has an audio cd in it - wish I'd left the map cd in now so at least the sat nav would be fully working. I have read on here that the amplifier maybe red if it is not fitted however I get absolutley no sound from the speakers and all the source options on audio are greyed out and cannot be selected - also the sat nav reads no audio on it.
Only found the upper glove box today lol, didn't even realise it had a cd changer. Can't seem to remove the unit to check the connections, ive tried electric screw drivers, wire coat hanger and even been and got some double din keys, it just won't move
3. There is a wire hanging down underneath the passenger front seat along with a plug and a bracket thing - is this something to do with the air bag system? Im guessing it should be attached to the bottom of the seat.
4. When using the remote central locking should the indicators flash? It does say they do in the manual but not on mine.
Thanks in advance for any help on these.
Also, when should the cambelt be changed and how much are we talking? It is 6 years old and done 24k miles.
Its going in for a full service on friday just in case as the record I have in the service book was last stamped at the end of 2006!
Thank you,
Stephen
Thank you,
Stephen
