stilo 2.4 abarth
stilo 2.4 abarth
fraserburgh aberdeenshire
hello ,,, i keep getting intermitten messasage saying fault with auto gearbox return to dealer ,,,,it seems to flash the message only when engine is warm and when turning ,,gearbox goes up and down gears without any problem even with this annoying message i dont no but could it be a fluid issue thanks for any help
The gearbo is a different unit to the Slespeed shift system. The gearbox is a standard 5 speed manual. The actuators(motors) move the regular gear shift'stick' to engage each gear. They work like little hydraulic rams. Another one releases and engages the clutch. The gearbox oil may benefit from a change, but it usually helps to improve shift speed only.
For more help try looking here.
Selespeed info
Its from the gearbox on Alfa 147 and 156s. Its the same system though, just looks a little different!
