Dpendragon
- Joined
- Dec 13, 2008
- Messages
- 2
- Points
- 1
Someone please help me. I've done all that I know to do.
24 hours after replacing the ignition coil in my 1977 FIat 124 Spider, It began to overheat.
I got her home checked the head gasket (ok) and decided to attack the easiest part first. I found and original Thermostat and put it on.
No Good. She was still overheating.
Then I noticed that the fan wasnt coming on.
Fisrt of all I just had all of the belts replaced and a full tune up including points and hoses. So I know for a fact that the belt is fine to the fan.
I had a friend of mine come over who is an electrician and he tested everything from the battery forward. We even removed the fan and hooked it straight up to the power. It just hummed along fine.
So why wouldnt it come on when the engine gets hot?
Thermal switch.
I replaced the thermal switch, which requires you to drain the radiator.
We put in the new one, refiled the radiator and....
TOO HoT AGAIN!
The switch wont tell the fan to come on.
Here is what I know right now.
THe top of the radiator is HOT. The bottom stays cold.
Today we flushed out the water in the radiator and refilled it and replaced the cap.
The only thing I havent done is put in the cleaning solution for the radiator.
All fluid that has come out of the radiator appears to be sediment free and "clean and Green"
Right now I have her rigged so that if I want to drive her, I open the hood, by pass the switch and connect the wires up, thus turning on the fan, then hop in to go for my ride.
Oh someone please help me?
Does anyone know what finnicky thing I need to do to make her happy???
Thanks so much,
:bang:
Thermal switch.
TOO HoT AGAIN!
Thanks so much,
:bang:
