Oh man :/Replace the wheel or get it recovered from what I've seen on here previously.
Worth a try. Thank youLeather shrinks as it dries out! I sorted a similar crease problem out on a steering wheel by the following method :-
Thoroughly soak the leather for about 100mm each side of the crease and also the crease with water , manipulate the crease out of the leather by gently twisting and pulling the leather away from the crease in both directions, hopefully successfully! Begin drying the leather by wrapping in kithen towels and squeezing, repeat as necessary, allow remainder of dampness to evaporate naturally or use gentle heat from e.g. a hairdryer.
Hope this helps,
Al.
Worth a try. Thank you![]()
That looks great. How much did that cost?
Around 180 pounds. But the leather is so much higher in quality than the original. The grip and feeling are great!
A company down here at Enschede, The Netherlands.What company did you get this from? The leather on my stearing wheel is pretty creased too
Two questions if you don't mind:-This was my solution:
Fresh new leather around the stearing wheel, and it looks and feels fantastic!!
1) The stitching looks more involved than on the standard wheel, is it still
comfortable?
2) Is that left foot rest standard or available as an accessory?
Thanks, Al.
It's definitely not available. There wasn't enough room to fit it in when the dashboard was rotated for right hand drive. I also believe the placement of the pollen filter stopped any chance of having a foot rest as it would be in the way to remove it.Not sure if that foot rest would fit in a right hand drive car? If it was cheaper I'd take a risk on it!
Should have got a Dualogic, I have one![]()
