General Standard tyre size
jimnewson
arborfield (reading)
hiya guys, i have a 1999 brava 80 sx, what is the standard tyre size that it comes with it. its just i'd like to know what the difference is in the speedo reading because i bought mine with 15' alloys and 195/45/r15 toyo tyres, and if possible can anyone advise me what size tyres i would need to get to get the speedo back to reading true? thanks for your time guys, james
thanks for the reply but thats not the size of the tyres that come as standard is it, its just i need to know the standard tyre size so i can calculate the difference, thankyou for your time.
thanks guys its just according to my sat nav (which i know isn't pin point accurate) when doing 70 im really doing 63ish and when doing 60 im really doing 54!!!!! its just irritating! is there anywhere i can get it tested? thanks to all though, take care.
Thats becaus eyou have a 10% difference in the diameter of your wheel. So 1 revoloution is shorter than it should be.
Heres the calc for you:
http://www.miata.net/garage/tirecalc.html
So no point getting it tested as GPS is backing this up!
very funny!!!! but i think i'll choose the former!!!! thats sound just right though according to the diagram. thankyou very much, i dont suppose you could tell me what size tyres i would need to get it reading more accurate? thanks again.
Depend on what your rims will take. Once you know the range you can play about with sizes and see the difference, you'll almost always have upto 3% diff which is acceptable.
185/60R14 I would think.
Mine is a 100 Trofeo with them on or 15's which i dont know what size
firstly: thankyou to all who have replied. secondly: after further research i have discovered that they are bk racing 166 alloys and they dont make this model in 15' so i went out and measured mine, turns out their 16 inch alloys running 195/45/r15, i always thought that the 'r15' was the diameter of the alloy or steel wheel meaning that it was 15' diameter, 195 was the width of the tyre and 45 was the depth????? so if i was right should my tyres be 195/45/r16???? sorry if this is confusing:bang:
Impossible. The rim is either 15 or 16" and the tyre will be the same diameter in inches.
If your tyre say 195/45R15 then your rims are 15".
The distance you probably measured was from lip to lip, not where the tyre bead sits :D
pk thanks mate for clearing that up!!! i did just measure from lip to lip, its just bk racing website says it doesnt do bk166 alloys in 15' only 14,16,17,18, so i measured it to 16' and figured they must be 16'!!!!!!!!!!!!!thanks again!!!
