Spark plug gap's must be right!!!
Robs
Just found out the cause of my punto not idling right by measuring them.
The gap should have been 0.08mm but they were way off by 0.02mm:bang: using a spark plug measuring tool.
Easy mistake when having a service,so i'll be doing that myself!:D
I thought it would be something like that, but I doubt that'd make a huge difference (unless, maybe, it was 0.2 too big -- coils might struggle to make a decent spark).
A 20 or 25% increase in spark gap is highly unlikely to produce a problem at idle. Even the old Kittering ignition systems (mechanical points, fitted to nearly every car many years ago) would rarely fail to make a spark at idle.
At full throttle and at high RPM you might notice a breakdown in ignition performance, but modern ignition systems are so good that I doubt a slightly incorrect spark gap is the OP's real problem. Certainly you wouldn't expect it to show up at idle.
