Spacers size (Abarth Punto Evo)
OCZedd
Established member
Bucks
Hi been along time here
Anyway looking at getting some spacers for my abarth punto and how to get a safe flush fit, ive done some measurements but round here its hard to find level ground and so its not the same clearance on both sides but i moved the car around abit and got it close and took more than 1 measurement and i am thinking averaging to the middle should work out? Because closer i gotto level ground the numbers got closer in towards the middle average value and these are pretty close now i think. Anyway here are my measurements (all in mm):
(Left front/Right front
Left rear/right rear):
Number1:
15/18
27/28
Number2:
15/18
27.5/27.5
Number3:
18/14.5
27.5/29
Based upon these measuremtnes what spacers would you recomended front and rear?
Sizes i can get here are 5,12,16,20,22,25,30mm (last 3 slightly more expensive)
I was thinking front 12mm and rear 25mm as i dont want the front to be wider than the rear just in case. This sound reasonable is it gonna be safe enough?
I'm trying to make the tires fit flush with the bodywork as on the abarth it has flared arches and the wheels sit too far inside the fender, not too fussed about handling but want it to be safe and look good. Yes all are hubcentric.
Think I will go for 20mm in the rear but not sure how to match it up to the front. Also the sizes 5, 6 & 8mm are not hubcentric, is this bad? But 10mm and above are so is it better to get these?
