Sophos
Sophos
Are you still having problems with this?
If you downloaded it from your Uni, where is it updating from? The chances are, and if the Uni are following the Sophos Licence Agreement, that you are updating from the Uni and so there is every chance that they have pushed policies into the software. This means they could have set the Sophos Firewall to be a tad restrictive.
If you need any help, give me a shout...been administrating Sophos since 1997!(y)
Okay, the first and simplest thing to try to make sure you get the latest Windows Updates onto your machine...disable the Sophos Firewall Service. Type Service.msc into a run command, scroll down until you find Sophos Firewall and then stop and disable the service.
Now do a Windows Update. Once its finished and rebooted, etc go back in and enable the firewall.
I'm just trying to find out which file you can alter to change settings in the firewall...we dont use it at work but I know most settings can be altered wven after being locked down.
Give the above a try and I'll get back to you as soon as I've figured it out!
