General  Some help with wheels please !
01marea16v
Herts
Some urgent help required
I have been hunting for a set of genuine Fiat alloys to replace the standard 14" steel wheels fitted to my weekend
Found a set on the web, delivered to me today
They have continental sport contact 3 all round, 6mm tread depth
When checking the wheels however, I notice that one set are 14" rims and the other are 15", tyres fitted 185/60/14 & 185/55/15
Question is, will they be safe to fit ? also what should be on the front and what on the rears ? (ie 14"'s on front and 15"'s on rear or vice versa)
Thanks in advance
Upon closer inspection the wheels are slightly different, one pair has 6 "holes" (14" pair) the other pair has 5 "holes" (15" pair)
Basically its now all a mess
However, my question of can I mix 14" and 15" wheels across axles still stands ?
You can put 14's on the front axle and 15's on the rear axle and vice versa, but you cant put a 14 and a 15 on the same axle.
Even if you put them on by axle pairs will still look weird.
Can't you get your money back and wait for a full set.
Waiting patiently for a response from the seller, hopefully he will do the right thing and supply me the correct wheels !
