Sidelight connector blocks for marea headlights
Ok there's been alittle problem when it comes to wiring your headlights, the guide wiring is based on the Haynes Manual, but MK2 cars have had a colour change in wiring for the sidelights.
If the guide ones dont light the sidelight, connect to the brown/yellow wire instead for +ve feed.
Joske
Cheers joske.
Mine is a mk1 so the guide you gave is right yeah?
Should be but double check ok.
I installed the lights on a Mk1 and Mk2 and had no problems, others complain. Joske
Joske
just check out my fitting guide... do a search.
its the wire 3 in the 4 wire block :)
Tommy K - Have you got the Bottle!!
Cheers Tommy,
Saw your guide and the lights look sweet. Was more just a Q about the connectors as they are brand new lights and don't have the connectors with them.
just use a pair of spade connectors.. do the same job just loads cheaper :)
M
1
818
Dark Lurker
J
6K
J
S
3
1K
Stephen01
S
E
1K
E
