Ducato side lights not an option
Tenko
Hi all not sure if i registered before with my last van a trigano tribute on the short wheelbase but now i have re registered with my new van another trigano on the 6m base.I have a problem with the side lights Its a 2013 model and there s no switch for the side lights The manual says they may be turned on using the multi function display but again its not shown in the options. They do work when I turn the only switch on (the headlights) Any help would be appreciated
That is how they work. You can no longer have sidelights only on when moving. Without the ignition on the side lights can be used for parking lights but dipped headlights, with side lights on as well, as a minimum when on the move.
Thanks for the info I was hoping to find a knackered relay since I have already checked all the fuses and havent found a post with the wiring diagram
The Highway code rule 115 says "use dipped headlights, or dim-dip if fitted, at night in built-up areas and in dull daytime weather, to ensure that you can be seen".
I guess that is what it is about i.e. no sidelight only running.
