General  sick marea help
andyman07
i have a 1.6 2001 sx. i broke down last night,the engine turns but doesnt fire up .it seems like the engine isnt getting any fuel (the plugs spark the crank turns)the fuel pump is working. has anyone got any advice or has had this problem.
i would be gratful for any input to help me thanks
the pump is priming i think had the aa come and he checked the pump u can hear it with th ignition on and tried the fuel cut off switch.
yeah the aa check for a sperk and all plugs were health and all the lights on the dash are on to.
hi to all, i had the car`s managament checked and it seem to be the crank sensor,(change over model strikes again)but as the air con is were the sensor should be does any 1 now were it is thanks
hi to all again, here an update.i got the car running yesterday after changing thecrank sensor,which work ok .this mornin i just when out to start it was fin when it got up to temp,the engine stared to over rev any ideas please
how could you have sparks when the crank sensor was faulty, thats not possible :confused:
high idle rpm when warm is usually due to a faulty idle speed controller on the 1.6, but you should try cleaning the throttlebody first.
