Technical Service ?
Technical Service ?
Whitland
Well my 1.2 easy has passed 10500miles. From what I can gather its due a service either 2 years or 18000 miles. I was planning on doing it at 12 months, old school thinking that 2 years or 18000 miles is too long.
Another option I'm thinking of is an oil change now and wait till I hit 18000 miles.
Any thoughts on this?
Oil change at least once between scheduled services or once a year minimum IMO. I will always stick to this as I believe the intervals to be too long for oil on some cars, 21,000 miles on my Bravo or 2 years - crazy.
No no, oil is when the car tells you on the 1.6 and 2.0 Bravo, not 2 years or 21k, might be even longer depending upon use :p
The way you've got to look at it is manufactures wouldn't be stating its ok unless is was overall, 5 year warranty on some Bravos, I doubt they'd leave oil changes longer than is safe if it means they may have to undertake warranty work etc.
So a oil change at 12 months, Still think 24 months is too long.
Oil will degrade more with use than age, its mileage more than duration between changes you want to keep an eye on so 24 months shouldn't cause to much of an issue.
How would you react if somebody offered you a secondhand car that was almost four years old, had done nearly 36k miles, but had only been serviced once in its life?
To maintain the resale value, an annual service is probably a good idea.
If its a FSH then its a FSH, over servicing it isn't going to increase its value.
Regardless of mileage, if near a service then you factor this into a purchase, but if its just had its 2nd service no-one will pay more for it because its had 4 services instead of the required 2.
