Technical Selespeed gearbox fault 2013 2.3 Multijet 130
ajc9664
Long story short, van starts and runs perfectly but gearbox error light on solid and can't select any gears.
I have scanned all modules with MES and the only fault found is "P0560-13 - Battery Voltage" in the Selespeed CFC348 Gearbox (Screenshot attached)
Fault won't clear even though the gearbox ecu reports same the voltage as other modules (12.2-12.3 ignition on, 13.5-13.6 engine running).
Now I am assuming it's a wiring fault, but I cannot find a wiring diagram for the facelift X250 with Marelli ECUs.
Any information gratefully accepted.
Thanks in advance
Andrew
If anyone has a similar problem here is what I found and how I fixed it
No KL30 (permanent +12v) on pin27 of gearbox ecu, possibly the secret F27 fuse has blown.
Without a wiring diagram I have no idea of how this power is routed to the TCU so I ran a 10 amp fused wire directly from the fusebox to the ECU.
Problem fixed.
