Tuning Sei manifold question?
oldham
Hello, there are 2 different manifolds for a sei yes ? (mines spi) i have the mani cat and thus if i de cat i need a whole new manifold. But there is a standard manifold to the cat under the engine is there not? And would this fit ? As would be cheaper haha. And noticing the sensor plugs are differently layed out and i believe one has 2 sensors instead of one. Mainly doing this as i want a good rally rasp ;)
If you have the mani cat one and the SPI, someone screwed up big style!
But, yep, the 1108 manis will fit all 1108s. You may just about (by the skin of your teeth) pass MOTs and VOSA spot checks by using an SPI mani, SPI cat, and getting another lambda boss welded on after the CAT.
Is it worth it? For the noise, I don't think so.
Hmm truee.... But yeah its only spi and i have a mani cat :/ but i got a stainless on at the mo and i only get a slight baurble at tick over mostly due to it blowing from front after clutch change... Think i broke something or moved a joint :(
Thats what i eas meaning having the plain mani to the bottom then strait into my back box ?
But would removing the 2 sensors(i believe mine has) cause it to run lumpy or would it cause any lights to appear ?
