scudo electricial problems
karl001
Hi I've got a 2003 scudo that won't start.The engine turns over but won't fire.When ignition is switched on the warning lights for glow plugs engine managment and abs do not appear. Have tried all fuses, glow plug relay, inertion switch, checked the earths, visually scanned the wiring can't find any breaks or loose connections is it the ecu or something else.Was running like a clock till 3 weeks ago had temps of -12 then this problem any ideas.:bang::bang::bang::bang:
:bang::bang::bang::bang::bang: Having an extremly bad f88king day today.....no futher along with the van (n) had a mechanic look and he can't get the diagnostic socket to read from ecu it will not connect. Have tested all the relays now and the glow plug relay has 12v in but no power out replaced relay and problem still exists with new relay:confused::confused: really stumped the mechanic as he was fairly certain it was the glow plug relay. Don't have power to glow plugs at all also as previously posted no warning lights ect......also no power coming thru to fuses behind glove box that control diagonostic socket/ warning lights ect......has any body had similar problems with the 2.0jtd :confused::confused: Could it be a problem with the dash clocks or is the glow plug relay twined to some other relay/fuse that is not listed or in a strange location:bang::bang::bang::bang::bang:
