Pete145
- Joined
- Jun 2, 2014
- Messages
- 288
- Points
- 85
Hi everyone,
This is closely linked to my recent alloy rocker/valve cover thread, but the subject seems to warrant a new thread I think.
I tried to install the new, aluminium rocker cover/valve cover today, as all of the bits had finally arrived.
I needed to fettle the corners a little (removing some material from the aluminium cover's corners, as the new cover was fouling own the engine shrouds/covers), and the breather hose is now too small to stretch across to the nozzle (which doesn't sit at an angle like it does on the standard tin rocker/valve cover).
However, there is a more serious issue. Specifically the new rocker/valve cover is taller than the tin version, I measured the height (albeit crudely) and was pretty sure than there would be enough length and thread on the stud bolts to fit the new cover..... I was wrong!
When I present the cover to the gasket, add the sealing washers and the standard washers, the stud bolts do not have enough height to take the nyloc nuts (I need 10-15mm more).
Does anyone know the standard length of the stud bolts, and where I might be able to source longer ones?
To thicken the plot a little, I know that both of the threads stripped in the modified cylinder head during the car's first drive under my ownership (some three years ago now). This issue was fixed by helicoiling the threads.
This makes me a little nervous about messing around with the stud bolts too much, should I be nervous and get this looked at properly, or will the helicloiled threads be rock solid?
