StefC New member Joined Dec 29, 2008 Messages 17 Points 3 Location Udine Dec 29, 2008 #1 Hi Guys I have a coupe 20 16v turbo when Im in 4th or 5th gear and floor the car, it seems to ride on the clutch. In the first 3 gears it OK. Is this turbo lag or is something wronge. Please help:worship:
N NigelO Member Joined Sep 1, 2007 Messages 159 Points 108 Dec 29, 2008 #2 sounds like the clutch is slipping - do the revs rise, but the car does not accelerate?
OP OP StefC New member Joined Dec 29, 2008 Messages 17 Points 3 Location Udine Dec 29, 2008 #3 Hi NigelO Yes the revs climb and the car does not speed up. but its strange that it does it only in 4th and 5th gear
J juggalugs New member Joined Dec 25, 2008 Messages 17 Points 4 Dec 29, 2008 #4 yeah its the clutch some times when the clutch first starts to slip it only effects 4th or 5th it will get worse in time and then it will happen to all the gears..
OP OP StefC New member Joined Dec 29, 2008 Messages 17 Points 3 Location Udine Dec 29, 2008 #5 Thanks will get it looked at
OP OP StefC New member Joined Dec 29, 2008 Messages 17 Points 3 Location Udine Dec 30, 2008 #6 quick question, this reving problem in 4th and 5th is there something I can ajust or must it go in to replace clutch?
marco20vt New member Joined Aug 20, 2008 Messages 115 Points 23 Location Bedford Dec 31, 2008 #7 Need to change the clutch!! mine is doing the same!!
OP OP StefC New member Joined Dec 29, 2008 Messages 17 Points 3 Location Udine Dec 31, 2008 #8 Thanks so that I will do next week, Dam more money. But its WORTH IT !
