Technical Reset airbag fault code
mrk79uk
I think I need to reset an airbag fault code and may possibly need to get myself connected to some diagnostic software to do the reset.
Total noobie here so I appologies in advance.
I have a 2010 3.0 multijet ex ambulance and I am looking for a nudge in the right direction on what software and leads to use.
I hope someone can help.
Kind regards
If you have access to the appropriate laptop, then this, or the software with equivalent cables/interfaces (other sources are available)....
https://www.gendan.co.uk/product_FESCAN.html
....should provide just about all facilities you might need.
It will diagnose and reset fault codes, etc. including airbag (assuming of course that they are not "hard" faults), reset oil and service intervals, etc.
Problems with the airbag ECU which require repair/replacement are not uncommon.
