Hi
i have a fiat tipo 1.6 mpi and i found a leak on the metallic pipe that goes into the water pump with the 2 in/out connections to the heater pipes in the other end. One of the pipe's heater connections has rotten and the heater's rubber pipe can't hold on to it so it leaks alot there.
Can that pipe be replaced easily without dealing with stuff like loosening belts, removing alternator and pump , etc?
Seems it can be done from under the car by removing the 2 bolts that attach the pipe to the pump and the rubber pipes on the other end, but i thought i'd ask as i'm not sure if there is room to pull the pipe out from there.
thanks in advance
thanks in advance
