General  replacing head
unoboy
canterbury, kent, United Kingdom.
i need to replace the head on my uno seeings as the valves are burned therefore what tools will i need to do this - mines the 903cc pushrod engine i dont have my haynes as it is in the car in london
any help would be appreciated Alan
Uno 903cc
New rear shock absorbers
Standard Tiny steel wheels
Pea Shooter exhaust
4x 2W 4" Cardboard Speakers
You Like?
You will need a torque wrench. you will need someone to look in there uno manual and post up head bolt loosening and tighting sequence (spelling) and also tourque settings.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
Undo in a progressive sequence.
Head tighten/slacken order:
(8)-(6)-(2)-(5)-(10)
(7)-(3)-(1)-(4)-(9)
stage 1 to 30 Nm
stage 2 to 59 Nm
Use a new gasket set.
Make sure all the surfaces are clean and grease free.
Make sure the head gasket has "ALTO" on top.
Rule of 9 to adjust the tappets
(whatever valve is fully compressed - say 3, 9-3=6, adjust 6.
turn engine until another is compressed, say 5, 9-5=4, adjust 4.
etc etc)
inlet 0.15mm
exhaust 0.20mm
