Technical Replacement turbo or turbo bearings
Hampshire
Does anyone know if turbos for the 1.9td are still available?
Having looked through ePer they are the same as the ones used in the Tipo 1.9 and it gives 3 part nos. i guess for different turbos. 2 are KKK? and one is Garret. Does anyone know the Garret model number?
If they aren't available does anyone know if the turbos are easy to dismantle and replace the bearings?
If not, i guess a new turbo would be needed.
Thanks, Craig
Thanks David, need to get it out and have a look at it first.
Previous owner said it was the bearing seals that had split. It was over double the emissions max reading when tested so oil is obviously getting in to the system somewhere or the turbo has somehow made the fuelling system go to pot.
