General Removing door panel doblo 2011
Meska77
Hey everyone.
I've uploaded a pic of what the door panel looks like when removed as this would have been useful for me when I did it recently.
You can see the location of all the plugs which are identical on the other side too.
First remove the caps where the door handle is on the inside. Under these you will find two torx bolts. I believe these are torx 40
Once bolts are removed gently pull up the plastic that the handle is attached too. You may need to pull it back wards a bit away from wind screen.
Don't pull too hard as there is a a cable and metal bar attached.
Undo the cable by pressing the tab in and gentle pull apart.
Next remove the metal bar from the handle. It just pulls out and has a clip to pull off
Next get a panel removal tool or carefully use a large flat head screw driver to undo all the tabs. Use the attached pic as a reference.
Once most of these are removed you can give the panel a sharp firm tug and the rest should undo.
You will then need to remove the plastic where the wingmirror is attached. Again use the panel tool or screwdriver to prize it off.
Next pull the panel up so that it detaches from the window slot in the door and you are done.
