Registration number: K891DKW
Mileage readings are currently only available for MOTs done from 1 August 2011.
- Vehicle makeFIAT
- Vehicle modelPANDA
- Date first used1 August 1992
- Fuel typePetrol
- ColourRed
MOT history of this vehicle
- Test date14 December 2015
- Expiry date13 December 2016
- Test ResultPass
- Odometer reading71,451 miles
- MOT test number4514 6546 9745
- Advisory notice item(s)
Shock absorber has a slightly worn shock absorber pivot Both fronts (2.7.4)
Suspension arm rubber bush deteriorated but not resulting in excessive movement Both fronts (2.4.G.2)
- Test date12 November 2014
- Expiry date1 December 2015
- Test ResultPass
- Odometer reading67,511 miles
- MOT test number4797 6681 4428
Offside Track rod end ball joint dust cover deteriorated, but preventing the ingress of dirt (2.2.C.1c)
Oil leak
boot floor corroded but not within prescribed area
- Test date7 November 2014
- Test ResultFail
- Odometer reading67,510 miles
- MOT test number1584 4131 4300
- Reason(s) for failure
Nearside Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Oil leak
- Test date5 November 2013
- Expiry date1 December 2014
- Test ResultPass
- Odometer reading64,252 miles
- MOT test number4070 7960 3437
Nearside Front Suspension arm ball joint dust cover damaged, but preventing the ingress of dirt (2.4.G.2)
Nearside Front Suspension arm has slight play in a ball joint (2.4.G.2)
Drivers door hinge deteriorated but the door can still be readily opened and closed (6.2.B.2)
Front passenger door hinge deteriorated but the door can still be readily opened and closed (6.2.B.2)
- Test date9 November 2012
- Expiry date1 December 2013
- Test ResultPass
- Odometer reading63,846 miles
- MOT test number4178 2481 2322
Nearside Track rod end ball joint dust cover deteriorated, but preventing the ingress of dirt (2.2.C.1c)
boot floor corroded tow bar mounting area (tow bar not fitted )
- Test date8 November 2012
- Test ResultFail
- Odometer reading63,845 miles
- MOT test number4374 6371 2395
- Test date8 November 2011
- Expiry date1 December 2012
- Test ResultPass
- Odometer reading62,943 miles
- MOT test number4877 8251 1346
Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
- Test date16 November 2010
- Expiry date1 December 2011
- Test ResultPass
- MOT test number6201 5042 0350
Offside Front Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
- Test date9 November 2010
- Test ResultFail
- MOT test number5646 8301 0371
Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Exhaust has part of the system excessively deteriorated (7.1.1a)
Exhaust has a major leak of exhaust gases (7.1.2)
- Test date11 November 2009
- Expiry date1 December 2010
- Test ResultPass
- MOT test number4010 7561 9384
Exhaust has part of the system slightly deteriorated (7.1.1a)
- Test date10 November 2009
- Test ResultFail
- MOT test number9917 4471 9324
Nearside Front position lamp(s) not in good working order (function impaired) (1.1.4a)
Seat belt has a cut which has significantly weakened the webbing (5.2.2a)
- Test date13 November 2008
- Expiry date1 December 2009
- Test ResultPass
- MOT test number8013 1851 8348
- Test date12 November 2008
- Test ResultFail
- MOT test number9220 8701 8375
Body has a sharp edge caused by corrosion (6.1.C.1)
- Test date8 November 2007
- Expiry date1 December 2008
- Test ResultPass
- MOT test number6734 9231 7334
- Test ResultFail
- MOT test number4648 1231 7442
Nearside Rear Seat belt anchorage prescribed area is inadequately repaired (5.2.6)
- Test date6 November 2007
- Test ResultFail
- MOT test number1628 2091 7345
Offside Registration plate lamp not working (1.1.5c)
- Test date15 November 2006
- Expiry date1 December 2007
- Test ResultPass
- MOT test number4540 1961 6495
- Test date14 November 2006
- Test ResultFail
- MOT test number3331 4821 6375
Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
- Test date18 November 2005
- Expiry date1 December 2006
- Test ResultPass
- MOT test number9615 4222 5310
- Test date15 November 2005
- Test ResultFail
- MOT test number5241 8901 5388
Offside Registration plate lamp not illuminating the registration plate (1.1.C.1e)
Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Nearside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Nearside Front constant velocity joint gaiter split (2.5.C.1a)
Offside Steering rack insecure (2.2.B.1a)
Nearside Steering rack insecure (2.2.B.1a)
Centre Windscreen wiper not operating over a large enough area to give an adequate view (8.2.1c)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
