Rear window heater doesn't work
T
Tom
The rear window heater of my P reg Brava no longer works. A few days before this happened, we had some sort of ominous warning: the heater warning light wouldn't turn off.
Could anyone suggest any possible remedies?
Tom
Thanks Andy - would it be a case of replacing the switch if it was at fault?
Tom
possibly or maybe some switch cleaner may do the job , hard to tell from here ;)
Bottom 2 strips dont work on mine any ideas, theres no breakages
Tom mine did same would not work or turn off
so last week i took the cover off in boot and found the wire was loose and had been shorting so cleaned it up put back to-gether works fine now :)
if it's just two strips whilst the rest are working it is deffo a breakage in the lines across the window.
M
1
547
Dark Lurker
S
5
902
captain kremmen
C
M
7K
mick gibbons
M
L
1
750
Tommy K
T
