Technical  Rear Wheel Bearing
Well I done my rear drivers wheel bearing tonight, such a doddle. Wheel off, caliper and disc off, hub nut and cover off then the whole hub flange just pops off. Torqued it up to 210nm then put everything back together. No more annoying drone and done in less than an hour from opening the garage door to shutting it.
Good job (y)
I'm having my break disks and pads done at the next service so may just get the bearings done as well. If it's as easy as you say. Though I will need a torque wrench. Where did you get the figure for 210nm may I ask?
