- Joined
 - Sep 2, 2007
- Messages
 - 151
- Points
 - 125
Hi again,
Not long ago, I was having a problem with a springy/squeaky rear suspension noise when driving over speed bumps (near side only), but not when rocking the car manually. This appeared after replacing rear shocks with a new (old stock, Boge) set bought on eBay.
Shortly before, I had to change the rear top mount shock bushes as old uns had perished. There was no noise at that stage but I did notice that there was excessive bounce on the near side causing the plastic cover to rattle and more thread showing at the spindle end of the n/s shock compared to the other side. Tried different bush but same result.
I thought that because the interior seal on the 'new' shocks might have dried out after being stored flat that was the cause of the problem but after getting a refund and substituting a second set, the same noise gradually reappeared (initially, squeaking could be heard when rocking the car, again near side only, though not the noise you get when handbrake is applied).
Boiling it all down, there seems to be something different about the near side. Checking previous threads (Punto, also Uno?), likely culprits might be:
1) overtightened handbrake clip holding cable to rear axle?
2) rear bushes-not certain if this is referring to top mount shock bushes already replaced or other ones altogether?
3) perished rubber sleeving on coli springs or varying rates of wear in springs themselves causing shocks to behave differently?
4)
Any suggestions welcomed-ta very much-apart from turning radio up louder!
Cheers,
Andy
4)
Cheers,
Andy
