Rear hub/stub/axle advice
RyanNI
Hi just joined and looking some advice... recently bought a home made car transporter, problem now is one axle has vauxhall hubs and the other has fiat... Question is what are they off
Bearing is built into the drum too... identical to these... but not!
I have got a complete mk2 punto hub drum brakes and wheel but the hub isnt the same
Any help appreciated
Can also supply a pic of the hub but because i am only new i cant post a link
Sorry its not offset I'm worried about its where the hub bolts to the axle, I will almost have 5 posts and can post the picture then!
Very like a punto drum I will try get pictures this evening
Sorry its not offset I'm worried about /snip/..........
I'm not worried about the offset (at this point!), but, if the wheel fits the hubs both sides, it's unlikely to be FIAT one side and Vaux the other -- the wheels simply wouldn't fit both.
All this assumes that it's not some wierd harold make it up as you go along match.
And leaf springs? Presuming dead axle?
Your right the flange where the wheel screws on comes away from the drum, I have tried the flange from a corsa d and it is identical... Although it doesn't go on the easiest, problem is whatever hub it runs I want to run the brakes of that car aswell so it just bolts on
