S Supermiko New member Joined Dec 2, 2009 Messages 10 Points 3 Mar 15, 2018 #1 Hi I can't open the rear door from the outside. Can't remember how to get the rear door handle off?
C craiggreg89 New member Joined Mar 2, 2018 Messages 9 Points 2 Mar 15, 2018 #2 I have a 2003 Doblo You will need to get access into the back and open the door from the inside by removing the door panel. Bolt on the inside of the door that needs to be removed and also one at the side of the door.
E Edtheted Member Joined Aug 26, 2010 Messages 103 Points 82 Location Midsomer Norton Mar 23, 2018 #3 My 2007 Cargo did the same I opened from inside then dumped a load of WD40 into and around the locking mechanism in the door,sorted.
