Wiltshire Chris
Accidental Barchetta owner
My 1999 Barchetta is now up on blocks in the garage for me to get some things sorted before the next attempt at the MOT.
First up was the ineffective handbrake. Its ineffectiveness was coupled with the fact it also didn't release particularly well.
Once I'd got the wheel off it was obvious from the grinding noise that the wheel wouldn't turn freely. With the handbrake off I could see that it wasn't springing back to its stop position.
I went to adjust the handbrake and, since it only goes up one click, suspect it has been tightened and tightened over the years to get it through the MOT. I've got new cables on order so just released the cables from the lever to give maximum slack. Still bit of a grinding sound when turning the wheel.
Since the discs had also an advisory against them I'd decided to change those out too. After much WD40 and resorting to stud extractors as the allen key sockets kept popping out I managed to get the studs out of the caliper. I was using the guide by Bumble which suggested a gentle tap would remove the caliper from the disc. Well, mine barely move and can't be persuaded off the disc, even with more than gentle tapping.
I wondered about using a big clamp to try and force the piston back in to the caliper but I believe that it's a screw type so I'm not sure if that will work.
Does anyone have any tips on what to try next? I'm a relatively novice mechanic but willing to learn. I suspect that even when I've got them off the calipers will need attention given how they are now.
Chris
Chris
