Hello.Friends.
During operation of the engine, bad reaction gas is too rich at idle.
If you try to fault diagnosis, I realized that feedback control of the O2 sensor is not normal.
I tried to replace the O2 sensor, but did not change it.
(., Which had a very painful spending)
After all, it is concluded that failure of the ECU, (connection to the diagnostic equipment've got interrupted!)
I'm decided to repair the ECU.
Reading on the target board of your own is removed from the circuit (Immo data! There is there) the CPU to save a backup of the data.
Here now.
I plan to replace the Xtal with the CPU.
Thanx.
Here now.
Thanx.
